[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PAS instance (11.7) does not appear in the Explorer connection when creating a server o
You have to deploy those webapps. You have always been able to do that from the proenv command line. See this KB for an example of doing it that way. Progress KB - OEManager is not installed during tcman create ... but the "easy" way to deploy from OEE has changed a little in OE 11.7. First of all I would highly recommend clearing your web browser cache if you had used the same browser to access the prior version of OEE in 11.7.6. (The user interface has changed over time, but the cache may pull resources from the earlier version of OEE, and that creates a total confusing mess because in OE 11.7 the OEE console has been redesigned .) Next find the web apps tab and deploy the pre-packaged web-apps from $DLC here: C:\Progress\OpenEdge\servers\pasoe\extras (Screenshot) Typically we deploy both manager.war and oemanager.war. Those are the ones that we use the most. Hope this is clear. Good luck.
