O
OctavioOlguin
this is biologin /*------------------------------------------------------------------------ File : BioLogin Purpose : Access control to packages sales Syntax : Description : Author(s) : Isai Padron. Created : Mon Nov 23 15:04:32 CST 2015 Notes : JOA 23/02/17 ----------------------------------------------------------------------*/ BLOCK-LEVEL ON ERROR UNDO, THROW. USING Progress.Windows.Form FROM ASSEMBLY. USING Suprema.UFMatcher FROM ASSEMBLY. USING Suprema.UFS_STATUS FROM ASSEMBLY. USING Suprema.UFScanner FROM ASSEMBLY. USING Suprema.UFScannerManager FROM ASSEMBLY. USING System.Drawing.Graphics FROM ASSEMBLY. USING System.Drawing.Rectangle FROM ASSEMBLY. USING System.IO.* FROM ASSEMBLY. BLOCK-LEVEL ON ERROR UNDO, THROW. CLASS procs.Bio.BioLogin INHERITS Form: DEFINE PRIVATE VARIABLE btnStart AS System.Windows.Forms.Button NO-UNDO. DEFINE PRIVATE VARIABLE components AS System.ComponentModel.IContainer NO-UNDO. DEFINE PRIVATE VARIABLE lbFinger AS System.Windows.Forms.Label NO-UNDO. DEFINE PRIVATE VARIABLE lblNombre AS System.Windows.Forms.Label NO-UNDO. DEFINE PRIVATE VARIABLE pBoxfPrint AS System.Windows.Forms.PictureBox NO-UNDO. DEFINE PRIVATE VARIABLE scannerManager AS Suprema.UFScannerManager NO-UNDO. DEFINE PRIVATE VARIABLE Scanner AS Suprema.UFScanner NO-UNDO. DEFINE PRIVATE VARIABLE Matcher AS Suprema.UFMatcher NO-UNDO . DEFINE PRIVATE VARIABLE ufs_res AS UFS_STATUS NO-UNDO. DEFINE PRIVATE VARIABLE SerieDelScanner AS CHARACTER NO-UNDO. DEFINE PUBLIC VARIABLE GlobalError AS CHARACTER NO-UNDO. // contiene los mensajes de error que se han obtenido. DEFINE PRIVATE VARIABLE minQuality AS INTEGER NO-UNDO INITIAL 50. DEFINE PRIVATE VARIABLE nType AS INTEGER NO-UNDO INITIAL 2001. DEFINE PRIVATE VARIABLE max_template_size AS INTEGER NO-UNDO INITIAL 512. DEFINE PRIVATE VARIABLE Template AS "System.Byte[]" NO-UNDO. DEFINE PRIVATE VARIABLE TemplateSize AS INTEGER NO-UNDO. DEFINE PRIVATE VARIABLE EnrollQuality AS INTEGER NO-UNDO. // obtenida por el scanner cuando lee una huella. DEFINE PRIVATE VARIABLE ptrTemplate AS MEMPTR NO-UNDO. // aqui se baja desde el registro de la db, para procesarlo. //DEFINE PRIVATE VARIABLE template2 AS "System.Byte[][]" NO-UNDO. cuando se haga match con todos los templates cargados.. ahora solo validamos que el usuario en cuestion, tenga un template que haga match. DEFINE PRIVATE VARIABLE pNominaEmpleado AS INTEGER NO-UNDO. DEFINE PRIVATE VARIABLE pOperacionSolicitada AS CHARACTER NO-UNDO. DEFINE PRIVATE VARIABLE pDedoARegistrar AS INTEGER NO-UNDO. DEFINE VARIABLE NominaIdentificada AS INTEGER NO-UNDO. // es la nomina del dedo que se acaba de leer. DEFINE TEMP-TABLE ttblobTemplates NO-UNDO FIELD TemplateField AS BLOB FIELD TemplateLenght AS INTEGER. /* vamos a validar todos los usuarios de una vez */ CONSTRUCTOR PUBLIC BioLogin ( INPUT pOperacion AS CHARACTER ): SUPER(). InitializeComponent(). THIS-OBJECT:ComponentsCollection:ADD(THIS-OBJECT:components). ASSIGN // inyeccion de parámetros... pOperacionSolicitada = pOperacion. ProcesaOperacion(pOperacion). THIS-OBJECT:CLOSE (). CATCH e AS Progress.Lang.Error: UNDO, THROW e. END CATCH. END CONSTRUCTOR. CONSTRUCTOR PUBLIC BioLogin ( INPUT pNomina AS INTEGER, INPUT pOperacion AS CHARACTER, INPUT pDedo AS INTEGER ): SUPER(). InitializeComponent(). THIS-OBJECT:ComponentsCollection:ADD(THIS-OBJECT:components). ASSIGN pNominaEmpleado = pNomina // inyeccion de parámetros... pOperacionSolicitada = pOperacion pDedoARegistrar = pDedo. //ProcesaOperacion(pOperacion). CATCH e AS Progress.Lang.Error: UNDO, THROW e. END CATCH. END CONSTRUCTOR. CONSTRUCTOR PUBLIC BioLogin ( ): SUPER(). InitializeComponent(). THIS-OBJECT:ComponentsCollection:ADD(THIS-OBJECT:components). CATCH e AS Progress.Lang.Error: UNDO, THROW e. END CATCH. END CONSTRUCTOR. /*------------------------------------------------------------------------------ Purpose: Notes: próximo a eliminar ------------------------------------------------------------------------------*/ /* @VisualDesigner. */ /* METHOD PRIVATE VOID BioLogin_KeyDown( INPUT sender AS System.Object, INPUT e AS System.Windows.Forms.KeyEventArgs ):*/ /* MESSAGE e:KeyValue */ /* VIEW-AS ALERT-BOX. */ /* END METHOD. */ /*------------------------------------------------------------------------------ Purpose:When the form loads, it checks if scanner is connected. Notes: ------------------------------------------------------------------------------*/ @VisualDesigner. METHOD PRIVATE VOID BioLogin_Load( INPUT sender AS System.Object, INPUT e AS System.EventArgs ): InicializaScanner(). IF pOperacionSolicitada = "Asistencia" THEN DO: THIS-OBJECT:CLOSE (). END. END METHOD. /*------------------------------------------------------------------------------ Purpose:Start scanning Notes: ------------------------------------------------------------------------------*/ @VisualDesigner. METHOD PRIVATE VOID btnStart_Click( INPUT sender AS System.Object, INPUT e AS System.EventArgs ): /* CASE pOperacionSolicitada: */ /* WHEN "Registrar" THEN */ /* RegistraH uella(). */ /* WHEN "Asistencia" THEN */ /* Registra Asistencia().*/ /* WHEN "Validar" THEN */ /* MatchEm pleado(). */ /* END CASE. */ leerHuella(). THIS-OBJECT:CLOSE (). END METHOD. /*------------------------------------------------------------------------------ Purpose: Notes: ------------------------------------------------------------------------------*/ METHOD PUBLIC VOID InicializaScanner( ): Scanner = ?. scannerManager = NEW UFScannerManager(THIS-OBJECT). ufs_res = scannerManager:Init(). Scanner = scannerManager:Scanners[0]. IF Scanner = ? THEN DO: reportaError("Error incializando el scaner"). RETURN. END. FIND Empleado NO-LOCK WHERE Empleado.Nomina = pNominaEmpleado NO-ERROR. ASSIGN SerieDelScanner = Scanner:Serial Scanner:Timeout = 5000 Scanner:TemplateSize = max_template_size Scanner
etectCore = FALSE Scanner:nTemplateType = nType. IF AVAILABLE (Empleado) THEN ASSIGN lblNombre:Text = Empleado.Nombre . RETURN. END METHOD. METHOD PUBLIC VOID LeerHuella( ): /*------------------------------------------------------------------------------*/ /* Purpose: Obtiene el template de una huella */ /* Notes: */ /*------------------------------------------------------------------------------*/ DEFINE VARIABLE ufs_res AS UFS_STATUS NO-UNDO. DEFINE VARIABLE Scanner AS UFScanner NO-UNDO. Scanner = scannerManager:Scanners[0]. IF Scanner = ? THEN DO: reportaError("No se pudo seleccionar el scanner dentro de los dispositivos de la computadora."). RETURN. END. lbFinger:Visible = TRUE. Scanner:ClearCaptureImageBuffer(). DrawCaptureImage(Scanner). ufs_res = Scanner:CaptureSingleImage(). IF STRING(ufs_res) <> STRING(UFS_STATUS:OK) THEN DO: reportaError("No se leyó nada desde el scanner"). RETURN . END. Template = NEW "System.Byte[]" (max_template_size). ufs_res = Scanner:Extract(Template, OUTPUT TemplateSize, OUTPUT EnrollQuality). DrawCaptureImage(Scanner). lbFinger:Visible = FALSE. IF STRING(ufs_res) <> STRING(UFS_STATUS:OK) THEN DO: reportaError("Error interpretando la huella"). RETURN. END. IF EnrollQuality 0: THIS-OBJECT:InicializaScanner(). THIS-OBJECT:LeerHuella(). Asistente = THIS-OBJECT:MatchEmpleado(). IF asistente > 0 THEN DO: FOR EACH ProgramaSucursal WHERE fecha = TODAY AND ProgramaSucursal.Nomina = asistente: ASSIGN ProgramaSucursal.Asistencia = YES ProgramaSucursal.HoraEntrada = TIME. END. END. END. END. RETURN. END METHOD. METHOD PUBLIC LOGICAL ValidaEmpleado( INPUT pNomina AS INTEGER, INPUT candidato AS "System.Byte[]", INPUT CandidatoSize AS INTEGER ): /*------------------------------------------------------------------------------ */ /* Purpose: Dado un Template recién obtenido de un empleado (candidato), carga todas los*/ /* templates asignado a el, para hacer un match con estos, y así validar que el*/ /* candidato esta registrado con ese template anteriormente... */ /* Notes: */ /*------------------------------------------------------------------------------ */ DEFINE VARIABLE ResultadoMatch AS LOGICAL NO-UNDO. // contiene el resultado del match que nos ocupa... DEFINE VARIABLE memptr2 AS MEMPTR NO-UNDO. DEFINE VARIABLE lenMem2 AS INTEGER NO-UNDO. DEFINE VARIABLE bytetemp2 AS "System.Byte[]" NO-UNDO. ASSIGN Matcher = NEW ufMatcher() Matcher:FastMode = TRUE Matcher:nTemplateType = nType // Scanner:nTemplateType = nType se usó en la captura original.. Matcher:SecurityLevel = 5. myVerify: FOR EACH EmpleadoTemplates NO-LOCK WHERE EmpleadoTemplates.Nomina = pNomina. ASSIGN memptr2 = EmpleadoTemplates.Template lenMem2 = EmpleadoTemplates.Longitud ResultadoMatch = NO // vamos a comenzar. esperando lo peor... ByteTemp2 = MemptrToByteArray( memptr2 ). // si bien, a continuación utilizamos la longitud del elemento BYTE[], y lo pasamos como // long. del elemento memptr, al parecer, las lognitudes de los dos elementos es la misma. Matcher:Verify(Candidato, CandidatoSize, ByteTemp2, lenMem2, OUTPUT ResultadoMatch). //System.IO.File:WriteAllBytes("C:\t\t.txt", Template). ASSIGN memptr2 = ? ByteTemp2 = ? SET-SIZE(memptr2) = 0. IF STRING(ufs_res) <> STRING(UFS_STATUS:OK) THEN DO: reportaError("Error extrayendo la huella para validar al empleado"). LEAVE myVerify. END. IF ResultadoMatch THEN LEAVE myVerify. //RUN procs\nom\RegistraAsistencia.p( Empleado.Nomina ). END. RETURN ResultadoMatch. END METHOD. METHOD PRIVATE VOID RegistraHuella( ): FIND EmpleadoTemplates NO-LOCK WHERE EmpleadoTemplates.Nomina = pNominaEmpleado // "Esa huella ya se habia registrado al empleado" AND EmpleadoTemplates.FingerIndex = pDedoARegistrar NO-ERROR. // "actualizar el registro anterior" IF NOT AVAILABLE(EmpleadoTemplates ) THEN DO: CREATE EmpleadoTemplates. ASSIGN EmpleadoTemplates.Nomina = pNominaEmpleado EmpleadoTemplates.FingerIndex = pDedoARegistrar . END. ELSE DO: IF (EmpleadoTemplates.Calidad > EnrollQuality) THEN // si la calidad actual es mejor que la anterior... no hacer nada RETURN. FIND CURRENT EmpleadoTemplates EXCLUSIVE-LOCK. END. ASSIGN EmpleadoTemplates.Template = ByteArrayToMemptr(template) EmpleadoTemplates.Longitud = TemplateSize EmpleadoTemplates.Calidad = EnrollQuality EmpleadoTemplates.Fecha = NOW EmpleadoTemplates.Nota1 = STRING(NOW) + " No. Serie del scanner: " + string(SerieDelScanner) + "~n" + EmpleadoTemplates.Nota1. FIND CURRENT EmpleadoTemplates NO-LOCK. RETURN. END METHOD. METHOD PRIVATE VOID DrawCaptureImage(INPUT Scanner AS UFScanner): // Purpose: Magically Drawing a image from scanner. DEFINE VARIABLE gp AS Graphics NO-UNDO. DEFINE VARIABLE rec AS Rectangle NO-UNDO. gp = pBoxfPrint:CreateGraphics(). rec = NEW Rectangle(0,0, pBoxfPrint:Width, pBoxfPrint:Height). Scanner
rawCaptureImageBuffer(gp, rec, FALSE). gp
ispose(). END. METHOD PRIVATE STATIC MEMPTR ByteArrayToMemptr (poBytes AS "System.Byte[]":U): DEFINE VARIABLE myMemptr AS MEMPTR NO-UNDO . DEFINE VARIABLE oIntPointer AS System.IntPtr NO-UNDO . SET-SIZE (myMemptr) = poBytes:Length . oIntPointer = NEW System.IntPtr (GET-POINTER-VALUE (myMemptr)). System.Runtime.InteropServices.Marshal:Copy (poBytes, 0, oIntPointer, poBytes:Length). RETURN myMemptr. FINALLY: DELETE OBJECT oIntPointer. END FINALLY. END METHOD . METHOD PRIVATE STATIC "System.Byte[]" MemptrToByteArray( pmptr AS MEMPTR ): DEFINE VARIABLE nPtr AS System.IntPtr NO-UNDO. DEFINE VARIABLE vInt AS INTEGER NO-UNDO. DEFINE VARIABLE nBytes AS "System.Byte[]". vInt = GET-SIZE(pmPtr). nBytes = NEW "System.Byte[]"(vInt). nPtr = NEW System.IntPtr(GET-POINTER-VALUE(pmPtr)). System.Runtime.InteropServices.Marshal:Copy(nPtr, nBytes, 0, vInt). RETURN nBytes. FINALLY: nPtr = ?. set-size(pmPtr) = 0. nBytes = ?. END. END METHOD. // - See more at: community.progress.com/.../100235 METHOD PRIVATE VOID InitializeComponent( ): /* NOTE: The following method is automatically generated. We strongly suggest that the contents of this method only be modified using the Visual Designer to avoid any incompatible modifications. Modifying the contents of this method using a code editor will invalidate any support for this file. */ @VisualDesigner.FormMember (NeedsInitialize="true"). DEFINE VARIABLE resources AS Progress.Util.ResourceManager NO-UNDO. resources = NEW Progress.Util.ResourceManager("procs.Bio.BioLogin"). THIS-OBJECT
BoxfPrint = NEW System.Windows.Forms.PictureBox(). THIS-OBJECT:btnStart = NEW System.Windows.Forms.Button(). THIS-OBJECT:lbFinger = NEW System.Windows.Forms.Label(). THIS-OBJECT:lblNombre = NEW System.Windows.Forms.Label(). CAST(THIS-OBJECT
BoxfPrint, System.ComponentModel.ISupportInitialize):BeginInit(). THIS-OBJECT:SuspendLayout(). /* */ /* pBoxfPrint */ /* */ THIS-OBJECT
BoxfPrint:BackColor = System.Drawing.SystemColors:AppWorkspace. THIS-OBJECT
BoxfPrint:Location = NEW System.Drawing.Point(12, 12). THIS-OBJECT
BoxfPrint:Name = "pBoxfPrint". THIS-OBJECT
BoxfPrint:Size = NEW System.Drawing.Size(170, 231). THIS-OBJECT
BoxfPrint:TabIndex = 1. THIS-OBJECT
BoxfPrint:TabStop = FALSE. /* */ /* btnStart */ /* */ THIS-OBJECT:btnStart:Location = NEW System.Drawing.Point(12, 286). THIS-OBJECT:btnStart:Name = "btnStart". THIS-OBJECT:btnStart:Size = NEW System.Drawing.Size(170, 33). THIS-OBJECT:btnStart:TabIndex = 2. THIS-OBJECT:btnStart:Text = "Escanear". THIS-OBJECT:btnStart:UseCompatibleTextRendering = TRUE. THIS-OBJECT:btnStart:UseVisualStyleBackColor = TRUE. THIS-OBJECT:btnStart:Click:Subscribe(THIS-OBJECT:btnStart_Click). /* */ /* lbFinger */ /* */ THIS-OBJECT:lbFinger:Image = CAST(resources:GetObject("lbFinger.Image"), System.Drawing.Image). THIS-OBJECT:lbFinger:Location = NEW System.Drawing.Point(12, 246). THIS-OBJECT:lbFinger:Name = "lbFinger". THIS-OBJECT:lbFinger:Size = NEW System.Drawing.Size(170, 28). THIS-OBJECT:lbFinger:TabIndex = 3. THIS-OBJECT:lbFinger:UseCompatibleTextRendering = TRUE. /* */ /* lblNombre */ /* */ THIS-OBJECT:lblNombre:Font = NEW System.Drawing.Font("Microsoft Sans Serif", Progress.Util.CastUtil:ToSingle(11), System.Drawing.FontStyle:Regular, System.Drawing.GraphicsUnit
oint, System.Convert:ToByte(0)). THIS-OBJECT:lblNombre:Location = NEW System.Drawing.Point(12, 341). THIS-OBJECT:lblNombre:Name = "lblNombre". THIS-OBJECT:lblNombre:Size = NEW System.Drawing.Size(170, 23). THIS-OBJECT:lblNombre:TabIndex = 4. THIS-OBJECT:lblNombre:Text = "label1". THIS-OBJECT:lblNombre:UseCompatibleTextRendering = TRUE. /* */ /* BioLogin */ /* */ THIS-OBJECT:ClientSize = NEW System.Drawing.Size(199, 373). THIS-OBJECT:Controls:Add(THIS-OBJECT:lblNombre). THIS-OBJECT:Controls:Add(THIS-OBJECT:lbFinger). THIS-OBJECT:Controls:Add(THIS-OBJECT:btnStart). THIS-OBJECT:Controls:Add(THIS-OBJECT
BoxfPrint). THIS-OBJECT:FormBorderStyle = System.Windows.Forms.FormBorderStyle:FixedSingle. THIS-OBJECT:Name = "BioLogin". THIS-OBJECT:StartPosition = System.Windows.Forms.FormStartPosition:CenterScreen. THIS-OBJECT:Text = "BioLogin". THIS-OBJECT:Load:Subscribe(THIS-OBJECT:BioLogin_Load). //THIS-OBJECT:KeyDown:Subscribe(THIS-OBJECT:BioLogin_KeyDown). CAST(THIS-OBJECT
BoxfPrint, System.ComponentModel.ISupportInitialize):EndInit(). THIS-OBJECT:ResumeLayout(FALSE). CATCH e AS Progress.Lang.Error: UNDO, THROW e. END CATCH. END METHOD. METHOD PRIVATE VOID ReportaError( INPUT cadena AS CHARACTER ): ASSIGN GlobalError = cadena. END METHOD. /*------------------------------------------------------------------------------ Purpose: Notes: ------------------------------------------------------------------------------*/ METHOD PUBLIC INTEGER UsuarioValidado( ): RETURN NominaIdentificada. END METHOD. DESTRUCTOR PUBLIC BioLogin ( ): ufs_res = scannerManager:Uninit() . END DESTRUCTOR. END CLASS. ... Are you implicating that I could call the class with out showing? It would be nice... I call this object with the : rTemp = NEW BioLogin ( "Asistencia" ) . WAIT-FOR rTemp:showDialog(). So I taked out the WAIT-FOR, and worked like a charm...
