[progress Communities] [progress Openedge Abl] Forum Post: Re: Oepas1 Instance Not Shown In...
E
egarcia
Hello, I wonder if this might be an issue in PDSOE. Do you see the same behavior if you remove another service (one that you are not using)? After it is removed, can you add it back using the "Create Servers & Finish" option? Can you use a new workspace? The Servers view in a new workspace should list all the servers. If you cannot use a new workspace, perhaps, a workaround would be to manually update the servers.xml file with the configuration for oepas1. You can get the configuration by looking at the servers.xml in a new workspace. Location of servers.xml: workspace/.metadata/.plugins/org.eclipse.wst.server.core/servers.xml If you try this workaround, please let me know if it solves the issue. I hope this helps.
