[progress Communities] [progress Openedge Abl] Forum Post: Re: Oe Reference Arccitecture...
marian.edu
LOL, just said “using” node.js there is only a matter of installing it and the dependencies all in all 3-4 command lines… it’s not that different than using the PAS (new or old), you do not need to master Java/Servlets/Spring to use the “pure” OpenEdge solution do you? Point being, if Progress decides at some point to move from Tomcat to node.js I’m sure no one will even bother… it’s still a pure OE solution :) Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
