C
ChUIMonster
ProTop has always focused on taking data from the VSTs and meta schema and many other sources and presenting more meaningful insight than a simple "vst browser". In the past some people have been turned off by the character interface. Some people probably still are turned off by that. FWIW there is actually a 10.2A Dot Net GUI client but it turned out to be a major PITA to coordinate all of the Dot Net gunk for new builds as new OE releases came out. It was pretty. But it was also much more work to support than it was worth. There is still a character interface for working in real time on the server. Kind of like a cross between PROMON and the UNIX "top" command. This is extremely powerful. And free. Character interfaces are not as bad as some people think they are. There is also an optional background agent process that feeds a browser based view of collected data with lots of pretty charts and stuff. The free version shows you up to 8 hours of history. Paid versions show lots more history and include features like alerting. The agent process is very lightweight and stores nothing locally -- so you don't have to manage a local database and you don't need to worry about the performance impact of the monitoring tool.
