[progress Communities] [progress Openedge Abl] Forum Post: Re: Oe Explorer To Manage And...
  • Thread starter Thread starter cjbrandt
C
cjbrandt
I have used OEE and OEM for several years. We use OEE in dev, environments just to provide a GUI interface to the databases or app servers. We use OEM in prod to monitor and trend performance data. OEM is for monitoring OEE is really just a GUI interface because it lacks the features that OEM uses to monitor environments and trend data. Are you using OEE trying to monitor something , or you just want to see some stats ? Also the version of OEM or OEE you are using is very important so include that info. Our current version of OEM is 11.5.1 and it has a known issue with performance. 11.6 is supposed to address that. We had the best success when we were using 10.2B06 for the databases and OEM. Since upgrading the performance has gone down. You are correct, there isn't much information available from clients that use OEM, although there seems to be more in the last year or so.
