Tinco
Hi, I would recommend to open a Technical Support call on: secure.progress.com/.../custsupport the registration steps are described on knowledgebase.progress.com/.../000033353 as this issue might involve more troubleshooting and research. Some generic (non OpenEdge) instructions on Oracle Database Gateway are available on: www.progress.com/.../oracle-database-gateway Which version of OpenEdge is being used? which SQL query is failing? what is the error message received? Does the same SQL query succeed when executed through JDBC: knowledgebase.progress.com/.../P15898 or ODBC: knowledgebase.progress.com/.../how-to-test-an-odbc-connection-dsn-on-windows-using-powershell directly on the OpenEdge database? Kind regards, Tinco
