[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Newbee Pro2 - Pro2SrcPDB missing when trying to replbatch1.bat
  • Thread starter Thread starter Satya Prasad
Satya Prasad
Pro2 by default generates these 3 fields ( pro2created, pro2modified and Pro2SrcPDB ) as part of the target schema generation for each of the source table(s). These are kind of tracking fields when the record got created/modified. So, Re-pull the dataserver schema with these fields and re-generate process libraries. Now, try to run replbatch1.bat. This should work. Thanks, Satya
