[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Network Database Connection Pause using VMWare - vmxnet3 vs. e1000
  • Thread starter Thread starter Libor Laubacher
L
Libor Laubacher
> Please note that during testing Rob did reduce the memory down to 128 GB and lower such that numactl showed a > single node IMO, 32vCPUs won't fit into 1 single NUMA node, they will span across 4 (or 3 if the HyperThreading is on). It's possible that Node interleaving feature is enabled (and it should not be) which would explain the numactl single output, but that information is not available in this thread. I am assuming that the C/S test is done from Windows and that Windows is also a VM, tho it is not specified explicitly said here.I would try same C/S (in Rob's environment) stress test on Linux to further clarify where the hiccups issue resides as well as getting the last VM tools off vmware.com site (10.3.2) - my.vmware.com/.../details > We are going to try the ESXi 6.5 version and we will test again. Why not 6.7 ?
