[progress Communities] [progress Openedge Abl] Forum Post: Re: Need Help On Ibm Mq - "error...
  • Thread starter Thread starter Sivarami Reddy Marella
Hi Anand, Thanks. I have changed Ip address and i have restarted my admin server and Sonic MQ adapter. Now I am receiving the below error. 1. My websphere MQ is installed in one machine, the same IP I have provided in my client connections and checked then I have received user authentication error. 2. Where I have my all programs, this IP I have provided in my client connections and checked then I have received the below error. I have 2 IP's in my client machine i have tried with both the IP's. 1. Ethernet adapter Local Area Connection: IPv4 Address 2. Ethernet adapter VirtualBox Host-Only Network: IPv4 Address S-0001>(Aug 10, 2017 14:51:52:803) : Looking up ConnectionFactory in JNDI Object Store S-0001>(Aug 10, 2017 14:51:52:804) 192.168.56.1::sonicMQ1::3620::ef54940a8d2b9a05:426b6e3a:15dcb711771:-7feb: Using connection values: 26,null,true,,true,false,-1,-1,false,0,false,false,,10000,0,30,false,60,0,20,0,,null,null,PC302075,localhost S-0001>(Aug 10, 2017 14:51:54:969) 192.168.56.1::sonicMQ1::3620::ef54940a8d2b9a05:426b6e3a:15dcb711771:-7feb com.ibm.msg.client.jms.DetailedIllegalStateException: JMSWMQ2020: Failed to connect to queue manager 'SampleQM' with connection mode 'Client' and supplied CCDT URL 'file:C:/Users/492839/websphereMQJMS/AMQCLCHL.TAB', see linked exception for more information. Check the queue manager is started and if running in client mode, check there is a listener running. Please see the linked exception for more information. Thanks, Sivarami
