Anand Adike
Hi Sivarami, Thank you for sharing the logs. From the logs it looks like you are not using JNDI approach to connect Remote MQ. If you want to use JNDI approach you should place the AdminObjectFinder.jar file in the classpath . I think you current configuration is to use the local QueueManger but not the Remote MQ. Follow the steps that are mentioned in the earlier conversion to connect remote MQ. Thanks, Anand.
