Anand Adike
Hi Sivarami, We need to run the procedures from Client machine. Also, while connecting to MQ Remotely using JNDI approach we need to provide the connection factory name instead of QueueManager. From the logs it look likes you are using QueueManger name to connect MQ remotely using JNDI approach. To over this issue use the connect factory name. Hope this helps!! Thanks, Anand.
