[progress Communities] [progress Openedge Abl] Forum Post: Re: Need Help On Ibm Mq - "error...
  • Thread starter Thread starter Anand Adike
Anand Adike
Hi Sivarami, Create the JNDI context from MQ Explorer -> JMS Administered Objects -> Add Initial Context -> Select 'File System'. Provide the any directory path and click on 'Finish', it will create the .bindings file under specified directory. Now, create the Client Connections from Channels section. In order to create it follow the steps mentioned in the below thread. https://community.progress.com/community_groups/openedge_development/f/19/t/30343 Thanks, Anand.
