[progress Communities] [progress Openedge Abl] Forum Post: Re: Need Help On - Error...
  • Thread starter Thread starter Chaya Krishnappa
C
Chaya Krishnappa
Hi Anand, Below is the log detail: [16/10/13@17:27:03.681+2300] P-014144 T-008804 1 4GL -- Logging level set to = 2 [16/10/13@17:27:03.681+2300] P-014144 T-008804 1 4GL -- No entry types are activated [16/10/13@17:27:03.681+2300] P-014144 T-008804 1 4GL -- Logging level set to = 5 S-0009>(Oct 13, 2016 17:27:04:012) 10.242.244.47::sonicMQ1::3620::3a0c48e56235696c:-c9451c:157bd75f0ce:-7f4c: Startup Parameters: jmsServerName: null Point-To-Point brokerURL: tcp://CTSC00520904801:61616 user: admin password: admin clientID: null pingInterval: null transactedPublish: false transactedReceive: false singleMessageAck: false symbiontAdapter: false jmsDomain: true S-0009>(Oct 13, 2016 17:27:04:012) S-0009: Sonic receive message queue size set to 10 S-0009>(Oct 13, 2016 17:27:04:012) S-0009: Sonic browse message queue size set to 500 S-0009>(Oct 13, 2016 17:27:04:013) : In SessionContainer() S-0009>(Oct 13, 2016 17:27:04:013) : Creating JMS connection factory: tcp://CTSC00520904801:61616 S-0009>(Oct 13, 2016 17:27:04:013) 10.242.244.47::sonicMQ1::3620::3a0c48e56235696c:-c9451c:157bd75f0ce:-7f4c: Using connection values: 26,null,true,null,true,false,-1,-1,false,0,false,false,null,10000,0,30,false,60,0,20,0,null,admin,admin,CTSC00520904801,CTSC00520904801 S-0009>(Oct 13, 2016 17:27:04:017) 10.242.244.47::sonicMQ1::3620::3a0c48e56235696c:-c9451c:157bd75f0ce:-7f4c javax.jms.JMSException: The connection was rejected by the broker - Did you forget to use ssl:// or http:// in your connect string ? at progress.message.jimpl.JMSExceptionUtil.createJMSException(JMSExceptionUtil.java:42) Thanks, Chaya
