[progress Communities] [progress Openedge Abl] Forum Post: Re: Need Help For Oe...
  • Thread starter Thread starter James Palmer
James Palmer
You are also not running after imaging on this database which means if you have a problem and need to revert to backup you will lose everything up to the point of the backup. It would be a good idea to look at implementing after imaging if you care about the data :)
