James Palmer
Yes a 32 bit client can connect to a 64bit DB server. As far as Type I/Type II, post the content of your db.st file and we can tell you whether it is one or the other. If the database was created from Empty4, then I would advise as part of the dump and load process to move to 8k block size (empty8). By the way, you don't have to solve all this yourself. There are consultants out there who can help. Progress do consultancy and I can recommend a non-Progress consultancy also if you want. Send me a message.
