Satya Prasad
1. why\how did this occur, is this beacuse we didn't enable the Database Triggers at the same time as the Bulkload ? and is this something we should do for future tables ? Yes. This might be the reason for out of sync. The right sequence is, enable database triggers and then bulk-load the tables. Once bulk-load completes then turn on the replication threads to process the updates in the replqueue. 2. The missing 500K is probably the difference between the Bulkload starting and the 7 days it took to finish, so that would imply that the Record count is taken at the start of the bulkload ? so everythin after that should be an update ? and should the Table trigger not have transferred the 500K ? This 500k is the difference between the time-gap of enable trigger vs bulk-load. More the gap among them will cause more records to be out of sync. 3. the most important, how do we rectify this, would stating a Bulkload again for that table be a risk ? as it is 70 millions records in the table I would not want to have truncate the Target Table and start again from scratch especially just for 500K records I am not aware of any solution to rectify this other than bulk-load of that particular table. However, if you can know those 500k rowid’s then you can rectify by creating replqueue records for those 500k records. Hope this Helps, Satya
