Tinco
Hi Dominik, On Windows you could also use ODBC and powershell as I described on: knowledgebase.progress.com/.../how-to-test-an-odbc-connection-dsn-on-windows-using-powershell sqlexp is a java utility and therefore requires the java provided with the OpenEdge installation, if you want me or one of my colleagues from our technical support department to have a closer look at the used configuration then do not hesitate to open a technical support case. Hopes this helps, Tinco van Engen Technical Support Progress Software
