L
Lieven De Foor
It appears you can't get the value of a private property using reflection, which is a bit strange (it can be done in other languages so why was this designed this way?) USING Progress.Reflect.Flags FROM PROPATH. USING Progress.Reflect.Property FROM PROPATH. BLOCK-LEVEL ON ERROR UNDO, THROW. CLASS TestReflection.TestReflection: DEFINE PRIVATE PROPERTY PrivateProperty AS CHARACTER NO-UNDO INITIAL "Hello!" GET. SET. METHOD PUBLIC VOID PrintPrivates(): DEFINE VARIABLE Properties AS Property NO-UNDO EXTENT. Properties = GetClass():GetProperties(Flags
rivate OR Flags:Instance OR Flags
eclaredOnly). MESSAGE Properties[1]:Name SKIP Properties[1]:Get(THIS-OBJECT) VIEW-AS ALERT-BOX. END METHOD. END CLASS.
