[progress Communities] [progress Openedge Abl] Forum Post: Re: Longchar Conversion Error...
  • Thread starter Thread starter Garry Hall
Garry Hall
In your repro, can you just display the values of Table1.Description? And if so, does it look correct when you display it with -cpinternal UTF-8? I suspect that maybe some of the "UTF-8" data in your db is malformed.
