[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Kendo UI Builder v3.0: Is OpenEdge 11.7.3 Required?
  • Thread starter Thread starter Anil Kumar
Anil Kumar
Hi Carl, One of the reason for schema not being added/available in the catalog file could be because ‘schemaFile’ attribute pointing to an empty value. Ideally, schemaFile attribute in the Business Entity annotations should include the file name where the temp-table (or dataset) information is available considering the temp-table information (schema) is not residing in the same Business Entity file. Reasons for schemaFile being empty : There are times when we edit Business Entity to add annotations via ‘Define Service Interface’ wizard, it removes value of schemaFile in the Business Entity. Can you please check for the value of the schemaFile in Business Entity, provide appropriate value of the include file (or the file path where schema is available) and regenerate the ABL service such that a new catalog is generated. Hope this helps. Thanks and Regards, Anil Kumar
