B
Brian Laferte
Even if you get the ABL to decode this, you won’t have verified it so how can you trust the payload isn’t forged? If you are using .Net there is a dead simple control by Chilkat ( Jwt C# Reference Documentation ) that you can use to decode, validate, and create JWT tokens. If .Net isn’t your thing, there is a simple node.js package to do the same ( jwt ). If neither of those work for you and you are using PAS, Spring security can do all the heavy lifting and return a client principal to the ABL for easy handling, though the setup can be confusing the first time you do it. Brian Laferte 401-499-6666 'Ambition leads me not only farther than any man has been before me, but as far as I think it possible for man to go.' -- James Cooke
