[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Issues with PAS and network connectivity
  • Thread starter Thread starter David Cleary
David Cleary
I will need to confirm what versions support the tcp_nodelay property. We just added it to the README a couple of months ago. tcpNoDelay=1 If the value of this property is not zero, then the PASOE Session Manager will automatically set the TCP option TCP_NODELAY for all socket connections created between the Session Manager and the PASOE multi-session agent. This disables the use of Nagle’s algorithm, which is a technique used by TCP to reduce the number of small packets sent over a connection by delaying their transmission. Use of Nagle’s algorithm can sometimes cause performance problems for certain kinds of applications, such as OpenEdge, that typically send (relatively) large blocks of data. Default value of this property is 1 I will confirm what versions support this. Dave
