[progress Communities] [progress Openedge Abl] Forum Post: Re: Issue With...
  • Thread starter Thread starter Mani Kumar
Mani Kumar
Hi Ishak, Thank you for sharing the app.xml. I’m now able to figure out the issue and below are my recommendations: rb.newui.util.addEventListener is something, which will attach the Listener on page canvas element and as Siraj mentioned in his earlier comment, rb.newui.util.customEvents.rbs_pageRender fires on both update and refresh of pages and these listeners will be removed automatically on each page refresh. However, it is not in case of $(document). $(document).on will attach handlers to document root node and will not get automatically removed when doing update. The reason behind why you were seeing incremental pop-ups was that, each time we try to load the same page or move to other page instead of refresh, a new handler gets added but the old one is not removed. Hence it is not suggested to use $(document).on in Ajax based pages. To fix this, here is a simplified solution: When using in custom side bar: 2. On Ajax based pages: Also, if you would like to use in both pages and custom sidebar, please make sure that function names are distinctly named, else, you will end up having multiple pop-ups again. I’ve made the above changes in the application you’ve provided and re-attached it. Please try and let me know if it works at your end? Regards, Mani. (Please visit the site to view this file)
