[progress Communities] [progress Openedge Abl] Forum Post: Re: Is It Possible To Add An...
  • Thread starter Thread starter Richard Banville
Richard Banville
You do not need to set it per client. The startup parameter documentation is not clear that the new notify value only takes affect after the current client's notify time has expired. That is even though the server's notify time has changed, the client will not check for notification until its current notify time is exhausted. If you startup with 10 minutes, change it to 1 minute you may need to wait a maximum of 10 minutes before the clients check for notification. After that, the notify should take effect every minute. Idle clients are not supposed to block this from continue as they are in a poll loop, even if in a pause(). There are some activities which the client cannot be interrupted immediately and even though notified, the notification will not be honored immediately but they "should" be rare. I don't know about the web speed clients. I would hope that they were considered but I will have to check on that.
