[progress Communities] [progress Openedge Abl] Forum Post: Re: Intermittent Problem In...
  • Thread starter Thread starter tbergman
tbergman
While I don’t have an answer for this particular problem, we used MSXML for many years and found that it became subject to problems after Windows updates and for other mysterious reasons. Would work on some machines, not others etc. Sometimes, the Server versions worked, sometimes not. A big mess. If you can, I’d suggest switching to the .Net equivalent for whatever particular task is needed. For transforms, you probably want the System.Xml.Xsl.XslCompiledTransform class. Tom
