C
ChUIMonster
A quick and dirty dot-p to munge "prostrct statistics" into an easier to review format: /* stinfo.p * * output assumes that your window is at least 132 columns wide... * * pro -p stinfo.p -param /db/dbname * * * prostrct statistics dbname * ... * * Statistics for Area: Schema Area * * Files in Area: Schema Area * ... * Database Block Usage for Area: Schema Area * * Active blocks: 22618 * Data blocks: 11437 * Free blocks: 11181 * Empty blocks: 6 * Total blocks: 22624 * Extent blocks: 4 * Records/Block: 64 * Cluster size: 1 * ... * */ define variable lineIn as character no-undo. define variable areaName as character no-undo format "x(30)" label "Area Name". define variable areaRPB as integer no-undo format ">>9" label "RPB". define variable areaCSZ as integer no-undo format ">>9" label "CSZ". define variable areaActive as int64 no-undo format ">,>>>,>>>,>>>,>>9" label "Active". define variable areaData as int64 no-undo format ">,>>>,>>>,>>>,>>9" label "Data". define variable areaFree as int64 no-undo format ">,>>>,>>>,>>>,>>9" label "Free". define variable areaEmpty as int64 no-undo format ">,>>>,>>>,>>>,>>9" label "Empty". define variable areaTotal as int64 no-undo format ">,>>>,>>>,>>>,>>9" label "Total". input through value( "prostrct statistics " + session
arameter ). repeat: import unformatted lineIn. lineIn = trim( lineIn ). if lineIn begins "Statistics for Area:" then assign areaName = trim( entry( 2, lineIn, ":" )) areaRPB = 0 areaCSZ = 0 areaActive = 0 areaData = 0 areaFree = 0 areaEmpty = 0 areaTotal = 0 . if lineIn begins "Active blocks:" then areaActive = int64( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Data blocks:" then areaData = int64( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Free blocks:" then areaFree = int64( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Empty blocks:" then areaEmpty = int64( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Total blocks:" then areaTotal = int64( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Records/Block:" then areaRPB = integer( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Cluster size:" then areaCSZ = integer( trim( entry( 2, lineIn, ":" ))). if lineIn begins "Cluster size:" /* and areaName matches "*idx*" */ then do: display areaName areaRPB areaCSZ areaActive areaData areaFree areaEmpty areaTotal . end. end. pause. return.
