jakuosma
Appendix A: Frequently Asked Questions and Troubleshooting Tips docs.microsoft.com/.../ff817615(v=ws.10) How can I tell if my Remote Desktop session is using RemoteFX? You can confirm that your Remote Desktop session is using RemoteFX as follows: Check the event log inside the virtual machine. Event ID 2 in the Microsoft-Windows-RemoteDesktopServices-RdpCoreTS/Admin event source is written to the event log with the following text “Remote Desktop Protocol will use RemoteFX module to connect to the client computer. RemoteFX module is being used based on the server configuration, client configuration, and network connection.” If the Start Menu shows the Shut Down button, you are using RemoteFX. If you are not using RemoteFX, Log off will appear on the Start Menu. Regards Jari Kuosmanen
