2
2087
As Patrick has pointed out this does not apply to FUNCTIONS - which in my opinion is one very good reason to always use FUNCTIONS in preference to PROCEDUREs. A second reason is that incorrect parameters to a FUNCTION is a compile time error, whereas incorrect parameters to a PROCEDURE is run-time error. This doesn't answer your question if you avoid the use of PROCEDURE then you can avoid the whole type conversion in the first place.
