[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Use Corticon With...
  • Thread starter Thread starter James Arsenault
James Arsenault
If you're using OE BPM then you're likely using the Corticon Managed Adapter to call Corticon. This will make a SOAP call to Corticon passing the data as XML. Is the issue that you cannot pass strings with accent characters from OE BPM to Corticon. For example a string such as L'été est là If that is the case, we may need to get the OE BPM team involved. I just did a simple test of this within Corticon and don't see a problem. I am able to pass such strings in XML payloads to Corticon. Please confirm if my understanding of your issue is correct. Thanks, Jim
