Richard.Kelters
You probably find a solution in this class /*------------------------------------------------------------------------ File : bytearrayhelper Purpose : Syntax : Description : Author(s) : rkelters Created : Wed Jul 30 09:14:04 CEST 2014 Notes : ----------------------------------------------------------------------*/ USING Progress.Lang.*. ROUTINE-LEVEL ON ERROR UNDO, THROW. CLASS util.bytearrayhelper: METHOD PUBLIC "System.Byte[]" MemptrToByteArray( pmptr AS MEMPTR ): DEFINE VARIABLE nPtr AS System.IntPtr NO-UNDO. DEFINE VARIABLE vInt AS INTEGER NO-UNDO. DEFINE VARIABLE nBytes AS "System.Byte[]". vInt = GET-SIZE(pmPtr). nBytes = NEW "System.Byte[]"(vInt). nPtr = NEW System.IntPtr(GET-POINTER-VALUE(pmPtr)). System.Runtime.InteropServices.Marshal:Copy(nPtr, nBytes, 0, vInt). RETURN nBytes. FINALLY: /* nPtr = ?.*/ DELETE OBJECT nPtr. SET-SIZE(pmPtr) = 0. nBytes = ?. END. END METHOD. METHOD PUBLIC MEMPTR ByteArrayToMemptr( nBytes AS "System.Byte[]" ): DEFINE VARIABLE nPtr AS System.IntPtr NO-UNDO. DEFINE VARIABLE mPtr AS MEMPTR NO-UNDO. set-size(mPtr) = nBytes:LENGTH. nPtr = NEW System.IntPtr(GET-POINTER-VALUE(mPtr)). System.Runtime.InteropServices.Marshal:Copy(nBytes, 0, nPtr, nBytes:LENGTH). RETURN mPtr. FINALLY: /* nPtr = ?.*/ DELETE OBJECT nPtr. nBytes = ?. SET-SIZE(mPtr) = 0. END. END METHOD. METHOD PUBLIC LONGCHAR ByteArrayToLongChar( INPUT data AS "System.Byte[]" ): DEFINE VARIABLE result AS LONGCHAR NO-UNDO. DEFINE VARIABLE memStream AS "System.IO.MemoryStream" NO-UNDO. DEFINE VARIABLE streamReader AS "System.IO.StreamReader" NO-UNDO. IF VALID-OBJECT(data) THEN DO: memStream = NEW System.IO.MemoryStream(data). memStream
osition = 0. streamReader = NEW System.IO.StreamReader(memStream). result = streamReader:ReadToEnd () . DELETE OBJECT memStream. DELETE OBJECT streamReader. END. RETURN result. END METHOD. END CLASS.
