K
Kai Siegele
Hallo Laura, thank you for your answer. Perhaps it’s not really clear where my problem is. Let me try to explain: In the meantime I have created my form by hand: First i have created the dataset. Then I have created buffers. Then I have attached datasources for the tables to the buffers. Then I have filled the dataset. Then I have created the query for the dataset. Then I have created the binding sources. Then I have stuck together controls in my form and the binding sources. That was a long way to go, wasn’t it? For saving time I want to use the ProBindignSource designer to create bindings and it’s underlying dataset. Unfortunately I have not find a way how to specify the query. Do you have any idea? Kind regards Kai Siegele
