[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Debug Pdsoe Could Not...
  • Thread starter Thread starter cverbiest
C
cverbiest
My previous post should have read : All Telerik components are in the Telerik subdirectory of the assemblies directory. > What do you mean "installed locally"? Using the Telerik Control Panel application . I don't think it copies to the GAC, only to c:\programm files\telerik\ It doesn't work on my laptop, the setup on the laptop where it does work is similar. > I don't know anything about an assemblies.config file! There is a .config file for the executable (e.g., > prowin32.exe.config) which serves this purpose. Do you have the name right? assemblies.config allows you to put the dll's into subdirectories instead of one huge directory, it's a trick I learned from Mike Fechner, it is mentioned on documentation.progress.com/.../index.html , The probing tag is explained on msdn.microsoft.com/.../823z9h8w(v=vs.110).aspx I don't think the assemblies.config causes the issue but I'll test without.
