[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: How to connect the Hybrid Data Pipeline To an Open Edge Database
  • Thread starter Thread starter jhensley
jhensley
Can you try 192.168.10.18:8443/d2c-ui and 192.168.10.18:8080/d2c-ui If you can't get to the HDP WebUI using those URLs it is likely the server is not running or something is blocking access to these ports on the server. It would also be helpful if you could supply the log files from the server. You can generate a tar file by going into the /ddcloud directory and running ./getlogs.sh.
