[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: How to connect the Hybrid Data Pipeline To an Open Edge Database
  • Thread starter Thread starter jhensley
jhensley
The details suggest the load balancer routing is not configured correctly. Routing looks correct for getting to the Notification Server on port 11444 but it doesn't look like routing to the API on port 8080 or the On-Premises Access port on 40501 is configured correctly. Can you provide your load balancer routing configuration?
