[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Connect An Openedge...
  • Thread starter Thread starter Mike Fechner
Mike Fechner
Angular JS data binding. Sent from Nine Von: mainroad1 Gesendet: 22.07.2017 12:40 nachm. An: TU.Mobile@community.progress.com Betreff: RE: [Technical Users - Mobile] How to connect an OpenEdge datasource to simple HTML elements? Update from Progress Community mainroad1 Maybe there must be some sort of *glue* between the OpenEdge datasource and the HTML... If that is the answer then must it be Kendo? Are they any other options? If the answer is that I must have a Kendo widget in between the OpenEdge datasource and the HTML then do I have to display the Kendo object in my mobile app? Imagine the simplest possible Telerik mobile app. It requests 1 record from the OpenEdge datasource and then wants to display a field of character data in an HTML text box. That is what I'm trying to figure out how to do. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here . Flag this post as spam/abuse.
