[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Connect An Openedge...
  • Thread starter Thread starter maura
maura
Hi Gord, In the sample Anil mentioned, if you look at detailView.html or editDetailView.html, you will see that they contain HTML elements that are bound to data model properties which correspond to the selected row of the ListView control (where the ListView control's Datasource property is set to the JSDO DataSource (accessing your OE backend data). Maura
