[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: How to compile with PCT to lowercase path and filename
  • Thread starter Thread starter Riverside Software
Riverside Software
If you generate PL files, option 2 can be implemented with a and between PCTCompile and PCTLibrary (as mapper are not supported at all in PCTLibrary). The conversion would still be my preferred way. A commit hook can be used to enforce the rule, or you can use the OpenEdge plugin for SonarQube . Gilles
