[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: How to compile with PCT to lowercase path and filename
  • Thread starter Thread starter Roel de Wildt
Roel de Wildt
Thanks for looking at the issue, sadly it won't be fixed in PCT There are 2 options now: - Converting the source in the source control system - Convert after the build with a post compile step before the pls are constructed I think I would correct the filename case in source control and enforce it in there with a rule
