[progress Communities] [progress Openedge Abl] Forum Post: Re: How Can I Call My Web...
  • Thread starter Thread starter Roy Ellis
Roy Ellis
Please note, that if you only have Progress Developer Studio on your local machine, the default database license will not allow remote connections to the database. By default the development database will allow direct connections and TCP based connections but only from the localhost. So yes, check to see if the remote agent.log shows an error about not being able to connect and this would be the reason why. To verify use a client from the remote machine and try to connect to the database to see the error interactively. Regards, Roy
