[progress Communities] [progress Openedge Abl] Forum Post: Re: Here's How To Wire A Kendo...
  • Thread starter Thread starter Thierry Ciot
Thierry Ciot
@smartsysISV: Yes we have several blogs covering these. Check: www.progress.com/.../high-performance-kendo-ui-grids-in-rollbase and www.progress.com/.../create-rollbase-custom-grids-with-kendo-ui for examples. Also, feel free to browse www.progress.com/.../thierry-ciot as there may be other examples relevant to you. These examples use the technique of getting the data from the server using a client side API and then populating a data source. As you pointed out, you could potentially compute the JSON data for your data source server side and store it in an object field – there are various trade-off of doing one versus the other – it depends on your own situation whether you want to use one or the other. Thierry.
