[progress Communities] [progress Openedge Abl] Forum Post: Re: Help With Certificate...
  • Thread starter Thread starter Brian K. Maher
B
Brian K. Maher
Alejandro, I did a test install of 11.3 on Windows XP where I selected a custom install but didn’t look at the individual pieces. The end result is that my install has the Perl directory so this means that during your custom install you somehow must have deselected the installation of Perl. You need to uninstall and reinstall. This time just do a complete install so you are ensured you will have everything you need. Brian
