B
Brian K. Maher
Hi Alejandro, You need to do this from the Proenv command prompt, not just a normal Windows command prompt. So the steps should be: 1) From Windows start menu on a machine where you have a full installation select the “Proenv” icon (a command prompt will be opened). 2) In the command prompt type “prompt $P$G” and press enter (this will show the directory & makes things easier). 3) Copy your certificate to %DLC%\certs (i.e. copy my.cer %DLC%\certs). 4) Run “certutil -import my.cer” (where my.cer will be changed to your certificate file name). 5) Zip up the %DLC%\certs directory. 6) Bring the zip file over the the Windows XP machine. 7) Backup the existing %DLC%\certs directory on the XP machine. 8) Extract the zip file into the %DLC%\certs directory (look at the directory after you are done to ensure that the unzip did not add an extra directory level, if it did you need to fix that). Brian
