[progress Communities] [progress Openedge Abl] Forum Post: Re: Fast(est) Way Of Doing A...
  • Thread starter Thread starter Peter Judge
P
Peter Judge
The array is just for the test, and in the real code is a TT field. The QUOTER is (in my real code) called just once per ‘param value’. You’re right – I should manually add “ to the ends of the string. I’m not sure how/whether “ is escaped in HTTP headers. Thanks for that. And you know my constraints on convmaps :) My thinking is that if I can get the AVM’s C code to do the most work (as opposed to the ABL itself) then that’ll be fastest.
