[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: FAIL - Application at context path [/restTest] could not be started
  • Thread starter Thread starter bauen@fordav.com
B
bauen@fordav.com
Thanks Micheal you pointed me to my answer. Turned out it was a compatibility issue in the WEB-INF/spring. I didn't have time to narrow down which combination of xml files were creating the issue, but I was able to determine it wasn't the authFilters.xml alone. For quick resolution I copied over the spring directory from a deployed webapp that was running.
