[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: FAIL - Application at context path [/restTest] could not be started
  • Thread starter Thread starter Michael Jacobs
Michael Jacobs
Spring Security error traces while resolving property values during web-app initialization are very verbose. The key information is: Error creating bean with name 'OEClientPrincipalFilter' defined in ServletContext resource [/WEB-INF/spring/authFilters.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'validateClientDomain' of bean class [com.progress.appserv.services.security.OEClientPrincipalFilter]: Bean property 'validateClientDomain' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter? The translation: 'the validateClientDomain property's value is attempted to be set in a Java OEClientPrincipalFilter class that does not support it'. That property appeared in 12.1. Could something be out of sync between your PASOE installation (in DLC) and the web app you are building?
