marian.edu
That’s just because of usage of ‘first’ (same with last) on a ‘for’ loop, looks like a bug to everyone probably at first encounter but then everyone at PSC will say it’s expected behaviour and that will probably never change mostly due backward compatibility thingy. The scope of the buffer just go one level higher than the enclosing for loop, that’s why if you put a do ‘nothing’ loop around the ‘leaking’ is fixed. Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
