[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Dump of SQL View
The SQL should be included in the output from dumping all schema. There is a utility. Progress KB - How to dump and load SQL-92 schema and data? Unfortunately we've had problems re-running the output from that utility and recreating an exact copy of the original definitions. I don't think it was designed with that purpose in mind. That would only affect you if you were trying to recreate *all* the SQL schema in the entire database. (all views, permissions, etc)
