marian.edu
Valeriy, what David depicted there should indeed work but I wouldn’t really go that route unless the only thing you have in your toolbox is a hammer… having a batch 4gl process to handle MQ messages, given it’s single threaded nature, the lack of control and the requirement of an ‘adapter’ doesn’t really compare with doing that in Java, just make a small web-app that you can deploy on tomcat - could even be the same instance running the PAS appsrv if you use that. All it has to do is have some sort of configuration - for MQ and for appsrv - make the connection to the appsrv, listen to MQ queue/topic and make the calls on the appsrv, if need be push the response back through MQ to anyone interested in the result. Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
