[progress Communities] [progress Openedge Abl] Forum Post: Re: Does The Pas For Oe Supports...
  • Thread starter Thread starter Valeriy Bashkatov
V
Valeriy Bashkatov
Hi David, Thank you for your clarification! Yes, I have noticed that my procedure is not completed after stopping agent. I had to manually kil that session. Do I understand correctly that the listener architecture should look like this: 1. Run the batch process, which will start my ABL-program (JMSServerExample.p with small modifications), for example by cron. 2. Once the process receives a message, it calls the procedure on an application server to process the message and waits for the result. 3. Once the result is received, the process sends a response to queue in ESB. In this architecture, I do not understand how to stop the work the batch process. I'm new to this. Maybe there are some ready examples to see how to implement it. Regards, Valeriy
